Trying to separate the H1C housing
Old Aug 23, 2019 | 09:54 PM
aeronb's Avatar
Anyone know of a good way to get the old stock housing off so I can put the new 12cm waist gated housing on? It seems to be stuck on there real good.
Old Aug 24, 2019 | 12:24 AM
mopar2ya's Avatar
I assume the turbo is completely off the truck. Spray it down with penetrating oil let it sit 30 min. Then tap the turbine housing around and around. Not love taps, but not crazy hard either. When it starts to move, lighten up. When installing use anti-seize on center section to turbine..
Old Aug 24, 2019 | 06:38 PM
Jim Lane's Avatar
After a glancing blow from my sledge hammer pinched my pinkie finger between the housing and the sledge hammer and mangled it, I took my h1c turbo to Becs ADP to have it completly rebuilt and balanced.
PB Blaster and maybe some heat might release it.
Jim
Old Aug 25, 2019 | 08:20 PM
aeronb's Avatar
I got it off. It took the bigger hammer after it soaked in PB blaster overnight.
Old Aug 26, 2019 | 04:19 AM
nonrev's Avatar
Super Moderator
10 Year Member
The old story that if you can't fix it with a hammer .... it's electrical
Old Aug 26, 2019 | 05:27 AM
Used a torch to warm it up, but not long enough to cause any melting l
mooktank
May 15, 2006 06:53 PM
BigWaylon
May 3, 2006 08:57 AM
DODGE 92
Sep 23, 2005 08:55 PM
Blueturbo
Oct 22, 2003 09:40 AM
