trying to do wiper linkage
Where did you get the bushings? I'm in need of them, nocied the wiper arms aren't going all the way back down but I can push them into place.
As to how to remove there are screws up there under the rubber, but as NUT said they are slotted so you can get them out without removing.
Ditto on the Napa part number. And here's some advice from a guy who replaced all of this bushings about 3 weeks ago. Once you have the cowl off, pull the entire linkage out of the truck. Once it's out, replace one bushing at a time so that you ensure everything goes back right. Then feed it back through the cowl opening and snap them onto the motor arm and wiper arm locations.
Replacing them in the truck is not suitable for young or sensitive hearing.
https://www.dieseltruckresource.com/...ghlight=wipers
Bill Gilbert's advice continues to be prescient. And the single most helpful tool in accomplishing this task is a good pair of Channel-Locks.
There was a post on this a month or so ago, and someone suggested drilling a small hole at the top of each bushing to allow air to escape when pressing it on. Also, I drop a little lithium grease on the bushing to try and help with longevity. It doesn't work that well, but I feel better about it anyway.
And yep, channel locks are your best friend!
2kayaks
Jan 25, 2014 06:01 PM
