Trying to get wiper arms off
Old Dec 2, 2006 | 01:39 PM
displacedtexan's Avatar
Trying to get wiper arms off- Figured it out
And I can't figure out how, is there some sort of release/set screw? It is cold (for here) out and I need to replace my wiper motor (never knew that using them to clear snow was bad...)
So how exactly do the buggers come off? Thanks a lot for any help.
on edit:
I figured out the tab that held them up, I knew it had something to do with it, just took a few tries to figure out how it all worked together... but got it now.
Old Dec 2, 2006 | 03:17 PM
AlpineRAM's Avatar
On mine it works like that: Lift the wiper blade until you can either push or pull the little tab that sticks out near the joint. In the right position the tab will snap in or out (don't remember this exactly) and the wiper arm will stay up)
Then wigle the arm gently and it will come off. Do this with the wipers in parked position and mark the position with some tape or the like. Repair or replace wiper motor, install and let it wipe some times without the wipers, turn off wiper and when the motor is back in parking position install the wipers by pushing them on , tilting up the arm a little and push or pull the little tab until the wiper will pull towards the windshield.
HTH
AlpineRAM
Old Dec 2, 2006 | 03:35 PM
Yep, same way on mine. It took a bit to figure out that I had to prop the arm up, I tried that, and worked like a charm. I didn't mark the position, I could see it on the window (I don't wash my truck all that regularly). I did let them run so the motor would be in the off position though.
New motor is in, wipers work. And I won't try to use this one to clear snow.
Old Dec 2, 2006 | 03:53 PM
derek840378's Avatar
i got the same problem on my 1st gen, but i have no tabs
2kayaks
Jan 25, 2014 06:01 PM
corn binder
Dec 10, 2010 12:03 PM
derek840378
Oct 18, 2006 04:09 PM
SIXSLUG
Sep 16, 2006 05:19 PM
Raspy
Mar 26, 2006 11:04 AM
