Truck Scaring Me....
Old Jun 26, 2012 | 11:11 PM
Farmboy12357's Avatar
Ok, this might be my imagination but on my drive home today, Going 50mph or so for about 8-10 minutes. My egt's seemed to be about 200 degrees higher than normal, and when I parked I popped the hood and the coolant was pretty hot and I slowly opened my radiator cap and coolant was coming out of that. I don't remember it ever getting this hot on a short drive like that. Also my temp gauge started working off and on and isn't working now so I don't know my coolant temp. #4 injector is leaking out of the hold down nut a little bit and I'm going to tighten that on saturday. Any ideas on a problem? Thermostat? It seemed to be fine on sunday when I drove it last. what would you guys do? Or even worry about it?
Old Jun 26, 2012 | 11:15 PM
I've got 50hp Bosch injectors, and an hx-35 with a 12cm housing to add to my sig also. I know a small housing like that will cause high egt's, these just seemed to be higher than normal.
Old Jun 26, 2012 | 11:57 PM
jimbo486's Avatar
How long has it been since you last change thermostats? I would guess the one in there now could be bound shut.
Old Jun 26, 2012 | 11:59 PM
in the 3 1\2 years that I've owned it....Never. It seemed fine on Sunday when I drove it last. could be though. What about the water pump? How often do those go out?
Old Jun 27, 2012 | 12:14 AM
I need to fix my temperature gauge. Last week after about 100 miles of continuous driving at 65 mph. the temp gauge came on and was running cooler than I have ever ran in that driving condition. Not by much but it seemed to run cooler with the new injectors. it works on and off. What do I do?
Old Jun 27, 2012 | 12:57 PM
jimbo486's Avatar
Water pumps never seem to be the issue in cases like these. If it was the water pump, your gauge would be reading hot.
It's always been recommended to me that the cooling system gets a flush every 2 years and as cheap insurance, replace all the components, water pump, thermostat and upper and lower hoses.
Old Jun 28, 2012 | 09:01 PM
Moparbubba's Avatar
Didnt you say you had white smoke to?
Sent from my DROIDX
Bsplyr500
Dec 24, 2006 10:33 AM
brandon507
23
Jul 16, 2004 07:32 PM
natstayl
Jun 18, 2004 01:39 AM
sandpuller2004
14
Jun 4, 2004 12:14 PM
Herve
23
Mar 7, 2004 10:24 AM
