Truck missing at first start
Old Jun 30, 2017 | 07:15 PM
nonrev's Avatar
10 Year Member
Originally Posted by j_martin
A small leak in the suction line could do just what you describe. The small air bubble gets into a single injector line, and drops the pressure in that line (by being compressible) until it finally clears it. That injector would smoke white while that's happening.
The fuel in the line between the lift pump and the IP would fire the engine on the first one over the top, like it usually does.
Thanks tomorrow I will try to pressurize the tank and see if I can see any leaks,how much pressure should I use
Old Jun 30, 2017 | 07:35 PM
maybe368's Avatar
Just a few pounds is enough, 10 psi or so.Give it a few minutes,mine took about 10 minutes or so to show up...Mark
Old Jun 30, 2017 | 07:41 PM
nonrev's Avatar
10 Year Member
Thanks I will get on that tomorrow after I finish replacing the ujoints in the rear driveline
Old Jul 1, 2017 | 08:09 AM
j_martin's Avatar
10 psi would put 2 tons of force on the sides of the plastic tank. More like 1 lb air pressure.
Old Jul 1, 2017 | 08:49 AM
maybe368's Avatar
That might be true, but I put more than that into mine with no damage. It would also be hard to seal it up enough to be able to titrate the pressure down to 1, IMO...Mark There goes the medic in me again , it means to regulate the volume ...Mark
Old Jul 1, 2017 | 10:11 AM
cougar's Avatar
Don't do it with a full tank, it will come back at you when you let off the pressure.
Old Jul 1, 2017 | 05:31 PM
j_martin's Avatar
Which might be why your stock tank holds 36 gallons.
Old Jul 1, 2017 | 07:10 PM
maybe368's Avatar
If that were the case, then I would have a 3000 mile range...Mark
Old Jul 2, 2017 | 07:44 PM
nonrev's Avatar
10 Year Member
Ha ha that's one way to get a larger tank than I never thought of, I didn't get the chance to pressurize the tank but will in the next few days, I really appreciate the response's I have gotten that's why I like this forum
Old Jul 6, 2017 | 11:52 AM
nonrev's Avatar
10 Year Member
just a regular fuel cap taken apart then drilled it with a 31/64 bit the fitting screwd in tight
yes I know its cracking but I will replace
plastic insert
ok guys sorry it took so long finally pressurized the tank used 8 lbs and found a leak. the PO must have broken the hard line where it goes to the pump and he put it together with hose clamps and some type of plastic fitting! It looks like there has to be serious restriction going on right there. the truck seems to run a little smoother but still not quite right so cracked each injector it missed on every one so maybe it's just the restriction causing it. Anybody have any suggestions on how to fix that so it has no restriction? here are some pics
Old Jul 6, 2017 | 11:54 AM
nonrev's Avatar
10 Year Member
I'm thinking I better size the next ones down a bit LOL
Old Jul 6, 2017 | 12:04 PM
maybe368's Avatar
1024 X 768 is a good size, you can see the detail and it takes up very little server space.I would just replace the line all the way back. That is the lift pump,right? It looks like an easy fix...Mark
Old Jul 6, 2017 | 10:08 PM
mhuppertz's Avatar
Will run soooo much better!
Old Jul 6, 2017 | 11:06 PM
nonrev's Avatar
10 Year Member
Yes it is running a lot better but I think that changing the line from the tank to the lift pump will make a huge difference because of the restriction where the PO put the line together... I will continue to update as I go along.. thanks to all that have replied
Old Jul 9, 2017 | 01:30 PM
nonrev's Avatar
10 Year Member
Just a quick update I replaced the line from tank to lift pump with 5/16 rubber and replaced the lift pump as well (had to stay with the stock pump for now) that barb the PO fixed the line with only had a inside diameter of 3/16 no wonder the old girl ran like she did
raymond21
Aug 8, 2008 11:39 PM
forane2001
21
Oct 6, 2006 01:13 PM
busted
Aug 21, 2006 09:58 AM
torqueman
Mar 24, 2006 05:21 PM
