Injector recommendation question
Old Jul 6, 2017 | 01:07 PM
vr1967's Avatar
About to rebuild a '93 intercooled engine for my next conversion (3/4t 4wd with NV4500) Truck will be an everyday driver with occasional towing of my tractor to my other place (12-15k) and odds and ends as needed.
Engine will be stock, except for a 3rd gen manifold and HE351CW turbo, 3200 spring, fuel pin (Considering Denny T or Hungry Diesel) and a few pump tweaks (manifold needed for clearance, turbo because I already have)
Plan to get the injectors tested locally, but if they need rebuilt, should I step up to a 5x.011 or 5x.012? Primarily looking for mileage, but a little extra power never hurts.
Thanks
Old Jul 6, 2017 | 02:06 PM
u2slow's Avatar
I decoded my used injectors to be a 5x12 tip. I wouldn't put in anything smaller as a standard replacement.
Old Jul 6, 2017 | 02:14 PM
deere country's Avatar
Keep in mind the 3D gen exhaust manifold has round exhaust ports not oval ports like all 12 valve heads do. Their is a manifold that locates the turbo in exactly the same place as the 3D gen manifold does but has the correct ports for the 12 valve head.
Old Jul 6, 2017 | 02:41 PM
vr1967's Avatar
U2slow, I was thinking stock Intercooled injectors are 6x.009, but could be wrong.
Deere country, I know of the 12v manifold (pn3931744) but I already have the 3rd gen one from a left over project, and with 3rd gen manifold gaskets, it looks like it will work. If not, will keep my eye out for a 12v manifold.
Going by a bus lot I know of tomorrow to see if any 5.9 parts available
Thanks
Old Jul 7, 2017 | 10:32 AM
cougar's Avatar
The stock injectors are 6X.009. You should have them reworked to 6X.011. I've run 4, 5, 6, and currently 7 hole injectors. Next go around I'm going with 6X.011. I love the 7 hole, but hard to keep them clean because no one makes a VCO in 7.
Old Jul 7, 2017 | 12:22 PM
bigragu's Avatar
Just went thru this myself. In search for better fuel economy and some power. I swapped out my injectors two years ago to 5x12 VCO injectors, which came highly recommended by a popular injector vendor. He said " no haze, some power, and better fuel mileage". Not going to drop names, as they turned out to be crap. I should've followed my motto, as you get what you pay for. I went from 16mpg's to 11.95 mpg's, and a ton of hazing, after only two years.
After some research, I went with the dieseltuff line of injectors- 5x12VCO's. No bs promises were made, just told I'd be happy with them.
Finished the install two days ago, and the minute I started up the truck, haze is completely gone. Still have a ways to go to check on mileage, but if I get my 16mpg's back, I'll be happy. I'd like to get the 20+ mpg's that some folks get, but I truly believe either their driving like they have a pine cone taped to their bare foot, between the pedal, or they have a stock, unmolested truck, with no weight additions to it.
I used to have a reason for hazing, during the winter months. But here in CA, with temps at the high 90's, there's no excuse for the haze cloud at a stop light. I know it upsets other drivers, as I see them waving their hands to their nose and role their windows up. So far, I'm happy with these new injectors.
Old Jul 8, 2017 | 12:38 PM
cougar's Avatar
My worst offenders where the 4X.014, part of it being they where 155° SAC. The cleanest where the OEM 6X.009 VCO 145°. The 5X.012 and the 7X.010 are about the same in the middle. The 5X.012 where built on 370 marine 155° VCO nozzles. They hazed some at idle, but could really blow a cloud at WOT. The 7X.010 are SAC 145° nozzles. They haze a little less, but will puff a cloud with every stout throttle increase. Fortunately it's a short lived puff that end almost as fast as it starts.
Old Jul 8, 2017 | 07:08 PM
ofelas's Avatar
I would go bigragu's route. Go to dieseltuff.com & email him with your needs & goals.
Old Jul 9, 2017 | 08:36 PM
vr1967's Avatar
Thanks
NCTURBOS
Dec 18, 2006 09:09 AM
Srigs
Aug 7, 2003 06:29 PM
Srigs
Aug 6, 2003 11:23 AM
Srigs
May 13, 2003 01:48 AM
