Truck dies with quick throttle punch.
Old Feb 8, 2009 | 02:38 PM
truckdweld's Avatar
The title doesn't really explain what is going on. The truck starts and runs just fine. When i get on the throttle hard and than let off it will die. It will do it both in park and in drive. Seems to starve itself of fuel. Then it will start right back up with no issues. I have the pumped turned up, 3200 spring and a dennyt fuel pin. I was thinking that maybe this was caused by a failing lift pump but what do you guys think. Thanks for the help.
Old Feb 8, 2009 | 02:45 PM
Jet100's Avatar
How low is the idle? Mine will do that if my idle is way too low. Could be your starving it for fuel( BAD LP)
Old Feb 8, 2009 | 04:33 PM
DeanM's Avatar
Mine has been dying also, when I de-clutch to shift or stop. I replaced my lift pump and that didn't help. I though the gov. weights might be gummed up or something. It could be that my idle is too low but I don't think so.
Old Feb 8, 2009 | 07:10 PM
Sounds like you may have the throttle lever indexed too loose.
vintovka
Apr 30, 2012 12:38 PM
90 power ram
Oct 6, 2011 08:04 PM
bkoz
17
Oct 18, 2009 09:32 PM
dieselgringo
16
Sep 1, 2005 06:01 PM
