Transmission Question, Where can I get one?
My bad, it shows this in Jim's post at the top of this page. Also Firstgenfanatic shows the complete instructions in this thread:
https://www.dieseltruckresource.com/...nderbed+cooler
These coolers are not factory installed, rather they were a dealer installed part. Somewhere on DTR Jim Lane reprinted the Mopar installation instructions showing where the lines were cut, and hose routing. The steel line is cut pointing toward the trans, then the hose loops 180* toward the frame then to the cooler.
Thanks for the link to the install directions, I see the bypass valve that was mentioned. That looks fine, I was talking about the compression fittings and hose doing a 180 when the outlet from the transmission is already on the correct side to go to the cooler. I wouldn't be happy to see that on a brand new truck.
When I first saw the plumbing on my 1993 W350, I thought it was pretty shabby also. I bought it new off the dealers lot, so I did a little research to verify that it was indeed installed as the manufacturer intended.
Totallyrad
Jul 19, 2011 07:41 AM
ratat98
29
Aug 11, 2006 09:41 PM
