transmission question
Old Sep 29, 2009 | 08:26 PM
911stgen's Avatar
can i put an eaton fuller 9 speed in my truck?
Old Sep 29, 2009 | 09:02 PM
You can put anything you want in it with enough prybars/hammers... Guy on cumminsforum put a 10 speed in his D350 ... I kept up with the thread for awhile then stopped.. idk if he ever got it to work.
Question is... Why ?? major cab modifications would have to be done, Custom crossmember, Driveshaft, clutch setup.
Old Sep 29, 2009 | 09:40 PM
911stgen's Avatar
well i want to do a manual swap and im trying to find a transmission and i want to do something a little out of the ordinary so what would you recommend.
Old Sep 30, 2009 | 06:36 PM
Unless you haul heavy all the time I would not recommend a 9 speed or any other twin countershaft trans. The Cummins 5.9 has a nice wide power band, there's no reason to have a trans with 500-800 RPM gear spacing.
Use a Getrag or an NV4500.
Old Sep 30, 2009 | 07:49 PM
Benjamin b2's Avatar
yeh but think of how cool it would be
Old Sep 30, 2009 | 10:06 PM
911stgen's Avatar
i know im kinda going for the cool i want to do something not many have i want to know how hard it would be and what i need to make it happen
Old Sep 30, 2009 | 10:13 PM
peobryant's Avatar
With enough money, you can do just about anything you want t your truck.
Old Oct 1, 2009 | 07:00 AM
Billut's Avatar
fitting in a NV5600 in a D250 would get you the same headaches for installation as a Fuller (or anything too big), and it would be a better match for the 6BT.
Old Oct 1, 2009 | 08:35 AM
rtroutman69's Avatar
http://www.youtube.com/watch?v=2CG0Yx3cmsc
It's a chevy with a cummins conversion with a 10 speed out back. That skinny guy is going to have a big right arm within a year
Old Oct 1, 2009 | 08:36 AM
dzl_damon's Avatar
I'd have to agree on the further apart spacing of gears! I LOVE my 727 3 speed auto over my 518 with O/D and that's just a small difference. I love having a larger range of RPM through each gear, she pulls great.
However, rowing through 9 gears on your way to 60mph would sound fricken sweet!
Old Oct 1, 2009 | 09:58 AM
ADMOPARMAN's Avatar
Dang that is funny to watch.. A buddy of mine COMPLAINS about all the shifting he has to do with his 2000 Ram with a NV5600 all the time, I'd love to put him in that truck.
Old Oct 1, 2009 | 11:35 AM
NO_SPRK's Avatar
You could put an allison in it!
Old Oct 1, 2009 | 02:29 PM
unixcowboy's Avatar
What gives you the larger speed range in each gear is the 3.07's....
The 518 IS a 727 just with the OD on the rear of it. Gears are the same in both....
Old Oct 1, 2009 | 02:32 PM
NO_SPRK's Avatar
Yeah I miss my 3.07s. My truck tows better now but it was way faster before
Old Oct 1, 2009 | 02:55 PM
huron52's Avatar
I can understand the different part.... but with my 6speed manual.... I don't use all the gears all the time.
I have started in 2nd then 3rd then 4th skip 5th and on to 6th.
Of course I have skipped 3rd as well... 2nd, 4th,6th
Of course these are only done with a empty truck and I'm lazy
5th wheel on behind ... I use them all.
