Transmission Question
Old Feb 20, 2008 | 10:39 AM
Rafter B's Avatar
Question Transmission Question
Can I change a '90 non o/d tranny to a newer model. Also this truck is supposed to have 307 gears,but he says top end is 74mph. Soes that sound right? Thanx
Old Feb 20, 2008 | 10:55 AM
Free89W350's Avatar
Yes. I plan on swapping out my 727 in favor of a 47rh (which has a lock up converter). Here is a link to the thread in the stick about it. JD730 has done this to his truck and he gives a great explanation of what you will need.
https://www.dieseltruckresource.com/...hp?photo=34197
Hope this helps.
Old Feb 20, 2008 | 11:35 AM
Rafter B's Avatar
Than x, he says this truck has the 47rh, but no o/d. Where do I go from that?
Old Feb 20, 2008 | 11:50 AM
Free89W350's Avatar
Is the o/d not working? All the 47rh are a hydraulic controlled with a lock up converter and o/d and came in 94 an 95 then they switched to a 47re which is electronically controlled. The 518 o/d are called the 46rh I believe. and the non i/c trucks came trough with the 3 speed 727 trans.
I think I said this right and if not I'm sure someone will correct me.
Old Feb 20, 2008 | 12:15 PM
JD730's Avatar
You said it right, but in all cases the overdrive and lockup are controlled by electric solenoids, but I don't know how that link got screwed up. Your's goes to picture.
This should work better.
https://www.dieseltruckresource.com/...d.php?t=114702
Oh and 74mph sounds about right for a stock truck with 3.07's and a 727.
Old Feb 20, 2008 | 01:04 PM
Rafter B's Avatar
Thanx, missed that one too.
Dauntless
15
Aug 30, 2016 08:37 PM
turbospl311
Feb 4, 2003 09:14 AM
CRobey4393
Jan 16, 2003 07:54 AM
CNYRAM
Dec 23, 2002 11:32 AM
