Transmission filter height question
If the transmission filter is sitting too high in the pan, is it possible to suck the level of the fluid below the height of the filter during hard runs?
and if so, what happens then?
I have a Mag-Hytec double deep pan installed. It comes with an aluminum block that lowers the position of the filter, so it sits right above the bottom of the pan. I did not install that block, so the filter is higher than it should be. So that is why I was asking.
Everytime I've had my stock trans pan off, the fluid level is clear up on the valvebody and the valvebody never stops dripping for the whole job. This makes me think that the filter is supposed to sit close to the bottom of the pan. That being said, if you ran it dry, I bet the trans' life could be shortened
Well I asked a guy I work with who used to work at a Dodge dealership back in the day, and he said it would cause rough shifting if the vb sucked some air. He also said this would not happen unless I took some really hard turns. He stated the fluid level remains constant once the TC fills with fluid.
In any case, I am still going to correct this as soon as I can.
If the fluid is filed to the stock level and the filter is at the stock height, it doesn't really care (or matter) how deep the pan is underneath it. Probably just doesn't cycle all the fluid consistantly.
LongRanger
Feb 2, 2010 10:03 AM
SNOW631
Dec 5, 2005 10:59 PM
mestdagh
May 7, 2005 07:23 PM
alvinator
Apr 3, 2003 05:00 PM
