Tranny cooler
Old Mar 30, 2011 | 04:17 PM
12valvewagon91's Avatar
Tranny cooler
Who on here has eliminated the factory tranny cooler for an after market cooler with a fan to cool it? The reason I ask is I recently rulled a FeDex truck out of a 3/4 mile black dirt/clay road, and the only way I could get to him was to drive to his rear and pull him 1/2 mile in reverse. I could not turn around, and I couldnt get around him to pull him straight. Well My tranny got close to 195 degrees. I stopped and let it sit and cool down to 150ish before finishing yankin the bone head out.
I was thinking of re routing a cooler with a small electric fan, and either mount it in the radiator support, or in front of the intercooler. I have yet to understand why they use engine coolant to cool tranny fluid as the engine coolant is at thermostat temp of 195.
Kasey
Old Mar 30, 2011 | 05:14 PM
307Kenworth's Avatar
When I was automatic, I had some not sure what they were but they were 2 great big coolers mounted in front of the grill. That trans puked and I didn't want to re use them so I got a RV trans oil cooler from Napa, substantially smaller than the others, and put it up front. Trans ran a lot cooler, but that was also due to it being a 47RH that I ran locked up pretty like a manual to keep the slippage and resulting heat down. When I intercooled my truck I bolted it on to one of the studs on the 2nd gen intercooler. Worked fine to the day that the automatic went away for a NV5600.
Old Mar 30, 2011 | 10:35 PM
THEBIGBULLY's Avatar
I still run my factory tranny cooler, but I installed a "Flex-a-lite" cooler to aid in cooling things down.
Up here I can't run the flexalite in the winter as my tranny will never warm up even with the fan not running.
So I just close that circuit and go back to stock.
I can't say enough good things about this product. I would have payed triple to get the performance it delivers.
MTC
Old Mar 30, 2011 | 10:38 PM
NE frmhnd's Avatar
The one my dad put on mine last spring has 3/8 inch inlets. Once I finally find one with full-length 1/2 inch tubing I am going to T this one in to run two in the summer.
Looked at some NAPA had on the shelf yesterday. They had 1/2 inch lines, but the ends were swaged down to 3/8. DUH!
Old Mar 30, 2011 | 10:59 PM
92smokin blacky's Avatar
I got a B&M cooler I believe with a fan and temp sensor that will kick the fan on with a relay when it hits 175*. Right now I just have the fan on a switch and watch my gauge, I've been too lazy to put the relay in. I got this fan on a trade and installed it on an angle under the battery tray with the fan on the backside sucking air through. I cut a big chunk out in front of it and it gets a little air from under the grille. It is at least twice if not three times the size of the stock trans cooler. I went this route since I installed a powerstroke intercooler and the stock one wouldn't fit and this one wouldn't fit anywhere else up front with the new intercooler. I may put it somewhere else one of these days but I haven't seen over 190* when pulling a load up a hill. I am planning on getting rid of the trans heater/cooler under the manifold when i put the twins in plus since it gets your tranny hot if your coolant is hot.
Old Mar 31, 2011 | 07:35 AM
So what do you guys consider deadly tranny temps? Ive been told 220 and up. Ive never had a gague before this truck, so In all my Gas engine trucks I have relied on the factory temp light. Never been an issue before, this truck is getting a rebuilt tranny as soon as I get thisgs rounded up, and Im gonna buy a cooling pan also.
Kasey
Tank_66
Jan 11, 2012 10:12 AM
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
gofastman
Nov 23, 2002 06:49 AM
DieselDaze
Oct 25, 2002 06:50 PM
