tps question
Old Mar 9, 2005 | 01:21 AM
HeavyRAM's Avatar
tps question
Ok,,so my tps is checking out ok..Is there a way to test the od shift solenoid?
I've got the in and out of od problem..
Old Mar 9, 2005 | 06:05 AM
Den's Avatar
Den
I'd really go for dropping the pan, replacing the filter and some new fluid. That fixed it on mine.
The solenoid is coil pack so you can test it for continuity. Should read 0 or close to it. It's hard to get to those 2 pins in the connector though. Might want to check it in the harness.
Here's the 91.5 wiring diagram. Not sure the differences in the 93 wiring.
Another thing is to adjust the kickdown lever. At idle you should have about 3/16-1/4 gap between it and the rod it rides on.
Den
Old Mar 11, 2005 | 03:37 AM
HeavyRAM's Avatar
Thanks den for the wire diagram..Turned out to be a bad ground,,Go figure..
Old Mar 11, 2005 | 04:39 PM
ChrisLib's Avatar
I`m having the same problem, what ground wire was bad, I`ve already rewired and cleaned the tps. My truck only does it if you drive it for more than 20-30 minutes, it must have to be good and hot for it too drop out.
Old Mar 17, 2005 | 03:01 AM
HeavyRAM's Avatar
I found two grounds loos..There is one on the fire wall kind of being the motor..It was loose..and the ground that come off the battery to the body that also has two groind wires to it was dirty..I cleaned and tighened both grounds and my problem went away..Your problem almost sounds like you need a trans service..fluid and filter change..
whosdunit
May 17, 2014 08:54 AM
Cummnzpowr
Jul 13, 2004 01:44 PM
Mike S.
Jan 24, 2004 05:19 PM
Farmall
Feb 8, 2003 01:02 AM
