towing mirrors on a 1st gen
Old Jan 14, 2006 | 12:53 PM
Buffman88's Avatar
has anybody made a way to where you can put towing mirrors on a 1st gen like the ones on a new dodge
Old Feb 2, 2006 | 05:32 PM
SWCODodge's Avatar
Bump.
I'm also in need of a good towing mirror system on my 1st gen - any suggestions? I've been using the plastic slip-over ones meant for the early gen 2's, but they're not big enough, and they vibrate like crazy at highway speeds. I'd like some that extend out like newer ones do, even if it's not fancy and powered.
Old Feb 2, 2006 | 06:07 PM
old dog's Avatar
REALLY old dog
If they are like mine,on my 92 350 dulie, i loosened the bolt in the bottum of the mirror and put the left on the right and right on the left, thes reversal puts them outside of the crome supports and gives you a good view and they are pretty stable.
Claude
Old Feb 2, 2006 | 07:15 PM
SWCODodge's Avatar
No, mine are more like the Chuvy style - a 90 degree curved pipe from the mount to the mirrow, the mount is below the window only.
Old Feb 2, 2006 | 07:37 PM
Duallydog's Avatar
I was thinking about using the stock mirrors and make a telescoping mount, like but shinnier (?) than the new (old) Chevy mirrors.
Old Feb 2, 2006 | 08:11 PM
flyingd's Avatar
Mirrors
**** makes a set of mirrors for the 1st gen trucks. They look just like stock but they have an allen screw that you loosen ant they extend out about 5 or so inches. Do a search for ****. BTW they are not electric.
Old Feb 2, 2006 | 08:32 PM
Dusty Ratcliff's Avatar
Old Dude,
if yours are the chrome or "stainless' towing mirrors, all you had to do is turn the heads over & then spin them inward or outward, just a thought in case you ever wanted to turn them back in, thought that might save ya a little trouble vs. unbolting both heads & switching sides again???? those bolts can be some mothers to break loose sometimes, just a thought, Dusty
Old Feb 2, 2006 | 11:05 PM
fishin fever's Avatar
Hey when i figure how to post pics i'll show you the custom mods po made to my electric mirrors but till then this explain will have to do something like the old chevy tow mirrors in that you can fold them in or out they fab a 5" ss flat piece with a fixed tread knuckle like fact then jion fac arm to this at this joint a small brace about 12'long is bolted to door with a jack bolt the wiring for the heads was extended as well at this joint i added 5' convex mirrors to both sides hmmmmm 1 pics worth 1000 words so befor you all ask i'll get on it . Eric.... ps till i looked close i through they were factory option
BRUISER
Feb 2, 2015 11:25 AM
BRUISER
Mar 1, 2014 01:13 AM
Justin erler
Aug 25, 2011 03:23 PM
csramsey640
Jun 11, 2006 06:14 PM
bigredbrick
Aug 22, 2003 02:37 AM
