took some pictures
Old May 21, 2009 | 01:38 AM
  #31
Alwaysworking's Avatar
alwaysonDTR
How many times you hooked that thing now?
Most of my southern tracks are real sticky clay, they'll hold a lot of power but you see lots of breakage then our northern tracks are right in the middle of loose and sticky kind of a sandy clay. Pretty good track prep around here too only got a couple of junk tracks
4 times twice on one track, next pull is the 30th and 31st so we'll see what happens, need to make ladder bars first thou
Old May 21, 2009 | 02:10 AM
  #32
pulltilbroke's Avatar
Best Paint (Getrag category)
Yeah Bars help a lot
Can you hang weight? Might want to fab up a rack and start hangin
My first hook is the 27th of June on a junk track just a little po dunk pull, only 2 mod diesels showed up last year so they ran us in the mod gas class (600-700 hp trucks)
This was one of the gasser trucks we pulled against(Not the actual hook from that pull)
http://www.youtube.com/watch?v=54Xwz...e=channel_page
and this is the other mod diesel truck that showed up
http://www.youtube.com/watch?v=KriVS...e=channel_page
Old May 21, 2009 | 08:45 AM
  #33
apwatson50's Avatar
Originally Posted by Alwaysworking
not much just like takeing off with a load in 1st high
So really not much at all. Do you build boost before you take off, or do you really just leave the line like you're pulling a trailer?
I'm thinking about doing a couple pulls, maybe this year but I don't want to smoke the clutch, but i'd also like to actually get the sled moving. haha
Old May 21, 2009 | 04:45 PM
  #34
how are you guys pullin with stock clutches?? they'll actually hold??
Old May 21, 2009 | 04:58 PM
  #35
I'm running a stock Sach's til funds will allow a DD, just relined it last fall it was gettin kinda weak, OK real weak
Old May 21, 2009 | 05:34 PM
  #36
You can't come out of the hole like the pro pullers do. You gotta pick a gear that lets you get moving without a lot of slip. If you don't get them hot they hold very well.
Old May 21, 2009 | 05:39 PM
  #37
apwatson50's Avatar
I was thinking you wouldn't want to do that anyways with the getrag and the small input shaft.
Old May 22, 2009 | 01:50 AM
  #38
alwaysonDTR
just like pulling a trailer, well almost i take off harder on the street with a trailer that i have sled pulling. and i do not do boosted take offs,
2nd lo worked fine for my first 12.25 stock replacement clutch for a while, i think the normal towing i do killed it.
Old Jun 8, 2009 | 01:43 AM
  #39
alwaysonDTR
under the hood
and i know the engine is dirty
Old Jun 8, 2009 | 06:30 AM
  #40
Are you going to make me ask about your intake?
Who/how did you make it and does it fit between the lines??
Looks awesome!!!!
Old Jun 8, 2009 | 02:11 PM
  #41
apwatson50's Avatar
Yep I want to know about that intake also, did you make a whole new intake plate? or cut a hole in the stock? NEED MORE INFO!!!!!
Old Jun 8, 2009 | 11:12 PM
  #42
alwaysonDTR
yes i made it, and it fits between the lines should just have to turn the clamps around, i cut out a new intake plate, dont have it on yet but once its all done i will post the results
Old Jun 9, 2009 | 08:23 AM
  #43
apwatson50's Avatar
How did you cut your plate out, CNC plasma? That looks mighty sweet!
Old Jun 9, 2009 | 10:42 PM
  #44
alwaysonDTR
cnc burning machine, it has both a plasma and oxy/act torches
Old Jun 10, 2009 | 10:05 AM
  #45
apwatson50's Avatar
So did you make a .dxf file from autocad or some sort of machine code? Are you using the cnc for the bolt holes also? Does it make small holes nice? At my old work we had a pretty old cnc plasma and it sucked for small holes, they just didn't take care of it at all
I was looking at the intake last night, while swapping injectors, and what are you going to do for the injector line holders? As it looks like if you move the one intake forward it may interfere with the injector holders for the front 3 cylinders. Maybe not?
Any chance you would make some of those plates to sell? How think are you making the plate, mild steel or ???
