Timing Help
Timing Help
I tried to advance the timing on my rig today without success ..... I was unable to rotate the pump. I even tried hitting it with a rubber hammer a few times, but she wouldn't move the slightest. I loosened the 3 nuts holding the pump to the gear housing & the sliding bolt on the vibration bracket at the rear of the pump. Do I need to loosen any more than that??? Or is it really that difficult to rotate. Thanx.
Re:Timing Help
Loosen your injector line clamps and the end of the lines that tie into the back of the pump. Also, there should be a return line fitting between the filter and the pump under the intake manifold. Disconnect the two and then try. See if this helps. This is what it took on mine to get it to rotate. Remember, only 1/8" above the stock mark is equal to about 1.40-1.45mm (15*) advance.
Re:Timing Help
Forgot to mention this. You also need to make sure the AFC boost line is diconnected on the back of the diapraghm. If not, you will take a chance of crimping the AFC boost line running to the intake manifold.
Re:Timing Help
Also, it is REALLY that hard to rotate. I had to use my forearm as a leverage point when I turned mine. I grabbed from underneath and gave it one hell of a twist while my brother was tapping with a mallet. I didn't think it moved but the lines were now seperated by a hair. so I tightened everything back up and it did make a difference so I left it there.
Re:Timing Help
Yup, some of them are the most orneriest, stubborn things you'll ever come across. Keep at it, just be sure to loosen everything that's been mentioned and you'll get it.<br><br>Bob.
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
