Timing case/ Front crank seal
Old Jan 29, 2008 | 03:07 PM
MoparMarv's Avatar
Getting ready to do the KDP while the truck is down for the head gasket. My buddy is out pricing parts. The autozone wants 38.00 for the timing case gasket(felpro) and 50.00 for the front crank seal(timken)? is this correct or are there better deals? Sounds a little high to me. Pay the price or shop around?
Old Jan 29, 2008 | 03:26 PM
90dodge's Avatar
crank seal
moparmarv,
I just now got off the phone with Cummins south here in Jacksonville Florida, and the parts man said it was $27 and some change. Heres the part #3937111, hope this helps ya out, whaen comes down to, try to buy the cummins parts, there built better, some times a little more, but its a piece of mind thing.
Bob
Old Jan 29, 2008 | 04:09 PM
woodrat's Avatar
After some of my experiences, I would lean towards genuine Cummins parts.
Old Jan 29, 2008 | 04:17 PM
dieselJon's Avatar
I got my front crank seal for $40.xx at O'Reillys. I do not know about the gasket.
Old Jan 29, 2008 | 06:02 PM
BC847's Avatar
1st Generation Admin
This should prove handy with installing that crank seal ~ https://www.dieseltruckresource.com/...d.php?t=126282
Old Jan 29, 2008 | 09:24 PM
GLHS's Avatar
Just bought my seal for $38 and cover gasket $17 from Cummins.
I also bought a 1st gen tab from TST Products for $8.
Old Jan 30, 2008 | 11:43 PM
dervolksfuhrer's Avatar
I went to Cummins today and priced... I did not get the part numbers but I was told $30.22 for the seal AND $22.84 for the timing cover gasket.
Total: $53.06
I'm going to have to call back and research the part number 3937111 $27 is much more preferable to a 50 dollar bill.
Old Jan 31, 2008 | 10:20 AM
GLHS's Avatar
Front seal kit # 3804899. Includes installer and dust cover. Supposed to work on all 12 valve Cummins.
Cover gasket # 3914385. Was told it will only fit VE pump trucks and the p-pumped cover gasket # is 3918673. Don't know the difference.
Old Jan 31, 2008 | 06:33 PM
Some more numbers...
I called Precision Automotive Diesel in Rockford today and they're offering
P#3914385 -- the timing cover gasket for $12.05
They're also less expensive on the crank seal @ $28.21
AND the head gasket P#3283335 for $97.79
I'm down south near Midway BUT they've beaten every price that my Cummins dealer in Hodgkins has given me. (22.84 -- 30.22 -- 104.78 respectively)
Old Jan 31, 2008 | 08:41 PM
ez_lle71's Avatar
I did my dad's 95' and my 92' kdp's in one day. the diff in gaskets is on the lower drivers side the timing cover makes a different jog over about a half an inch difference in the ve pumped motor vs. the p pumped one. Its just enough to require a different gasket. Got all the gaskets and seals from MHC Kenworth in salina a cummins dealer. About 100$ cheaper than oreillys on all the stuff.
ez
Old Feb 8, 2008 | 10:37 AM
GLHS's Avatar
Here it is.
Use the instuctions off TST's website to install the seal. I just did mine yesterday.
The clear plastic piece in the seal install kit is a guide. It stays in the seal while your installing the cover over the crank. Once the cover is held in with a few bolts you can pull it out, insert the thin dust shield and then install the crank damper.
I don't know why the Fluidampner would'nt work on yours. Is it possible there is a crossmember within 3/4" directly below the stock damper? If not, it should work.
Rimcrew
Aug 19, 2012 01:04 PM
sootnsmoke
Jul 17, 2011 06:31 AM
92smokin blacky
Mar 6, 2011 01:09 AM
92smokin blacky
Feb 28, 2011 02:36 PM
