timing advanced
Old Dec 1, 2005 | 11:17 PM
squirrel's Avatar
timing advanced
messed with the timing today. cranked it all the way up. man what a diffrence vs stock timing. temps are down boost is down and man it pulls harder when that pedal is on the floor! smokes less too. if it wanst for this site my truck would still be in the slow lane.
Old Dec 2, 2005 | 06:37 AM
G1625S's Avatar
Judging by your sig, sounds like a fun truck to drive! You definitely need a fair amount of timing when running pods.
Old Dec 2, 2005 | 09:10 AM
dzpoorjr's Avatar
How far does 1 go with the timing-I only moved it an 1/8 of an inch-should I take it over to head? As the little I moved it didn't seem to do too much! And can't seem to get the smoke down! The biodiesel I made made it run a little quieter and cut some of the smoke!
Old Dec 2, 2005 | 09:39 AM
tboling's Avatar
I have my pump moved one full tooth inside from stock plus it's almost hiting the head on the out side. I can move it one more tooth and still be safe. Runs like a viper.
Old Dec 2, 2005 | 05:43 PM
Zane, push the timing as far as you can move it. Like Greg said, POD's need a lot of timing to burn the fuel.
Old Dec 2, 2005 | 09:42 PM
squirrel's Avatar
thanks for the addvice in my other post wanna. the timming made a difference. feels stronger when wound out compared to befor. just need to take it back to the track and see if i can make better time
kida sounds like a power stroke now at idle.
AndyD
Jun 8, 2010 08:25 PM
WideOpenThrottl
15
Sep 21, 2005 03:00 PM
cumminsdriver635
Aug 29, 2005 09:51 PM
Crimedog
Apr 14, 2004 02:01 AM
Trickytrae
Aug 20, 2003 09:16 PM
