Time to pic a Turbo
Time to pick a new Turbo
Guys,
I called Steve out @ Mid West Transmission about building a 518 for me & he said what turbo am I running? I said why does that matter & he said to pick the converter you need to know the turbo to get the stall correct so it will spool up.
So I was thinking a S300 60/71/16 plat shaft.
I have so far;
PDI 3Pc Exhaust
Denny T 2
1/2" fuel lines
Fass first gen feed pump
Low pressure lift pump.
3200 spring
366 spring DDP 55 LPM sticks 80HP
I still have the stock valves
Stock head & gasket,head bolts.
I am thinking about head studs, valve springs & O ringing the head.
What is your recommendation for a good turbo for my setup?
Who is the best to call?
Where is the best place to order from?
PS;
here is Tex;
Jungle's new CTD RC called Tex - Dodge Ram, Ramcharger, Cummins, Jeep, Durango, Power Wagon, Trailduster, all Mopar Truck & SUV Owners. Dodgeram
I have so far;
PDI 3Pc Exhaust
Denny T 2
1/2" fuel lines
3200 spring
PS;
here is Tex;
I can't recommend a turbo but I can recommend studs for the head. I hit 44 pounds boost one time and stretched the stock bolts enough to allow coolant to leak out at number one cylinder near the thermostat housing. I am running a HTT Stage IV H1C with a 16 square centimeter exhaust housing with DDP Stage III 150 hp over stock injectors and a little water meth. Sixty pound valve springs are a good idea too. My EGT's are thru the roof. My EGT gauge quit last week so I am baby peddling the truck right now. Not a lot of fun but the fuel costs are down a little.
Its tough to beat the price/performance of a used WH1C, HX35, or HE351CW (all quick spooling).
I run the HX35 plus some fuel mods on an otherwise stock engine.
nonrev (05-10-2018)
S362SXE (62/68/12) if you are shooting for 400 to 450 HP.
HE351CW for 300 to 350 HP.
WH1C or HX35 for 250 to 300 HP.
All three will light quick.
60/71/16 would be absolutely terrible.
Thanks guys!!!!
I ordered my turbo yesterday. It is the S362sxe & should have it next week. I'm also going to get the 518 sent out this coming week.
Jim
Jim
DMS1707
23
11-05-2008 12:53 PM
