throttle linkage assembly
Old Mar 2, 2010 | 05:03 PM
19mike92's Avatar
does anyone have pictures or a step by step diagram of how the throttle assembly goes on these trucks. i was putting mine back together the way the instructions i found in the sticky said to do it but they were missing 3 or 4 of the peices. any help would be very appreciated. gotta get this b**** back together. cruising seasons coming soon.
Old Mar 2, 2010 | 08:07 PM
jimbo486's Avatar
see if this exploded diagram helps at all. the throttle linkage is about square in the middle of the picture.
Old Mar 2, 2010 | 09:02 PM
19mike92's Avatar
thats the same one I used before. its missing some prices. there's an extra spring and a plate like things.
Old Mar 2, 2010 | 10:57 PM
jimbo486's Avatar
do you have a picture or pictures of what you've got?
Old Mar 3, 2010 | 06:42 AM
19mike92's Avatar
I'll see if I can snap some today
Old Mar 3, 2010 | 08:01 AM
19mike92's Avatar
well for starters. there are plate like things in the diagram numbered 304, 289, and 72. they are all there but there is another plate that has 2 tabs bent 90 degrees off each side. its not in the picture. and there is a small spring about an inch around that isnt pictured either.
Old Mar 3, 2010 | 08:05 AM
19mike92's Avatar
the extra peice also has the hold in the middle with teeth around it so it would slide over the "throttle pin" but theres only enough room on the pin for one and i have 2 that need to go on.
Old Mar 3, 2010 | 08:47 AM
dzl_damon's Avatar
Hey Jim, that's the 114 pump's (non i/c) diagram. Slightly slightly different than the I/C pumps like Mike has. Perhaps that's why there is a discrepancy.
Old Mar 3, 2010 | 08:58 AM
19mike92's Avatar
that would do it. mines a 92 so its intercooled
Old Mar 3, 2010 | 08:59 AM
19mike92's Avatar
any one got one for an intercooled truck?
Old Mar 3, 2010 | 12:01 PM
jimbo486's Avatar
my fault. i had no idea there was that much of a difference. always details . sorry to mislead you mike!
Old Mar 3, 2010 | 01:24 PM
19mike92's Avatar
no worries. let me know if you hear of anything
DHunter
Oct 13, 2014 05:16 PM
Diesel_Power_2
Apr 8, 2013 07:01 AM
db
Sep 25, 2003 10:41 AM
gunracer1
Aug 24, 2003 07:30 PM
soundfetish
Feb 5, 2003 04:06 PM
