THREAD SIZE of FUEL SOLENOID ???
Old Apr 29, 2009 | 09:06 PM
BearKiller's Avatar
Question THREAD SIZE of FUEL SOLENOID ???
What is the thread pitch/size of the fuel-solenoid ??
Thanks.
Old Apr 30, 2009 | 06:03 PM
Big and metric?
Old Apr 30, 2009 | 08:24 PM
RollinCoalSmoke's Avatar
LOL wannadiesel that covers alot of territory. BearKiller I have an engine on the engine stand and i'll try to remember tomorrow to pull the solenoid out and see what it is. Hope that's soon enough.
Old Apr 30, 2009 | 09:28 PM
BearKiller's Avatar
Big and metric?
I looked hard, but didn't see any fittings listed as "big and metric".
YES, that would be wonderful.
I know that the big outlet on the lift-pump is 14mm x 1.5, but it seems to me that the fuel-solenoid may possibly be bigger.
My reason for needing to know the thread size is I intend to convert at least two, maybe three, of my trucks to cable-kill, yet I want to keep the perfectly good solenoids for whenever one should fail on the other trucks.
If my memory serves, a simple plug of the right size can be used, instead of "gutting" a perfectly good solenoid.
Of course, if I could come up with a few "dead" solenoids, I could just use them.
Thanks.
Old May 1, 2009 | 05:00 AM
KRB's Avatar
KRB
I think I kept my old one, if you want it I'll look.
Old May 1, 2009 | 08:21 AM
apwatson50's Avatar
You can just take the plunger and spring out, screw the solenoid back in and just keep the guts in the glove box and if you want the solenoid to work again, just put the guts back in. Should work right?
Old May 1, 2009 | 09:53 AM
Ace's Avatar
Ace
I converted my shutdown solenoid into a solid plug by punching out the plastic body and tapping the remains for a 1/2"NPT pipe plug. It's visible near the lower-right corner of this pic:
http://stuff.is-a-geek.net/PhotoAlbu...cs/CTD_172.jpg
Old May 1, 2009 | 11:15 AM
apwatson50's Avatar
I did almost the same thing, I tapped the smaller hole with 1/8"NPT pipe plug, then the little o-ring that actually seals it has something to hold it in place. The last thing I did was fill the cavity with some silicon.
Old May 1, 2009 | 11:19 AM
Ace's Avatar
Ace
Mine sealed up fine with no o-ring, just screwed in there nice 'n tight.
Old May 1, 2009 | 11:57 AM
apwatson50's Avatar
Obviously both ways work, I just didn't have a 1/2"NPT tap, had an 1/8" so...
Old May 1, 2009 | 12:20 PM
Ace's Avatar
Ace
The problem with mine was it started leaking past the plastic body about a year after I gutted it in favor of the pull cable.
Old May 1, 2009 | 06:14 PM
BearKiller's Avatar
Yes, I want it, if it ain't a lot of trouble.
Let me know if you find it.
Thanks.
Old May 1, 2009 | 06:19 PM
BearKiller's Avatar
What is that gizmo in front of the throttle ??; I assume it is a "turbo-timer" kill-switch, or maybe it tells an engine-brake where the throttle is at.
That looks like some of my welding, by the way, but I don't remember doing it.
Old May 1, 2009 | 07:17 PM
Ace's Avatar
Ace
You guessed it BK - ex brake switch.
Old May 1, 2009 | 07:28 PM
BearKiller I got the solenoid out but i'll have to wait until in the morning when my buddy brings back my tap and die set, the thread pitch gauge is in with that stuff. Haven't used any of it in a year and one of my guys loaned it out a couple of days ago. That's about par when your looking for something and it got loaned out, at least a good friend has it so i'll get it back in good shape and clean. Sorry but i'll try my best to have it tomorrow.
