Thoughts on 12cm housing
I currently have the lagmaster 21cm (non-wastegated) housing on my 91.5. Just wondering if there are any concerns with installing a wastegated 12cm. Looking for some input. Thanks
The 12cm housing is an excellent piece on autos and manuals. The added benefit on the 5 speeds is that you have to spool the turbo in every gear, so the 12 helps speed things along. Although you only have to spool up once with an auto, the smalller housing will still produce more boost for a given amount of fuel, which will help you run cooler when towing.
I have the h1c with a 12cm wg housing on my 91.5 auto. Stock injectors and mostly stock tuned pump and it hits the wastegate at 25psi and stays there. I think for a stock truck (injectors and tuning) it is a decent upgrade, as long as you don't block the gate or have bigger than stock injectors. Just be sure to hook the wastegate up! I drilled and tapped the compressor cover on the h1c for the wastegate hookup.
I love mine, and would never consider going back. It is a cheap mod, with huge gains on a 5-speed, and it still better than the 21 cm housing if you have an auto. It will give you more boost, and will keep your egt's a lot cooler! I love mine!
whats up bud,
you bought that off me.
anyways, it will be fine without much more fuel. If your plannin on gettin injectors, it will be on the small side, but then again, the whole turbo is for that matter.
One thing I forgot to tell you is you have to move your exhaust back 1.5"s because of the wastegated housing.
IMO everything is better than the 21cm.
If you want an all around good housing, swap the 21cm for a factory 18.5cm off a 89-91.0 or a 93 truck . low egt's on the highway and relatively fast spool up on auto trucks.
