Thermostat issue
Old May 4, 2012 | 05:04 PM
Roperteacher's Avatar
Thermostat issue
1996 12V with 116,000 on it. THermostat has been stuck open for quite a while ( Temp gauge has not got off the Cold in a while, used to run middle of the range). Driving today and temp gauge reading "Normal" right up the middle. Popped the hood and Pressure cap was COLD. Let it sit few minutes and when I came back ( About 20 min after shut down) cap was HOT as it should be. Water pump was just replaced about 500 miles ago. Is there a bubble in there? Thanks!
Old May 4, 2012 | 10:23 PM
hounddogks76's Avatar
Highly possible......did you loosen the plug above the thermostae and try to blee air out? It takes a 3/8 or half inch drive ratchet, can't remember.
duster75
13
Dec 30, 2013 11:33 AM
The_Head
Mar 6, 2010 01:01 PM
marine4life
Nov 6, 2009 12:51 PM
Bookshelf
May 30, 2009 01:17 AM
DDysput
May 5, 2004 07:44 AM
