Thanks
Old Dec 28, 2004 | 10:17 AM
92DIESEL's Avatar
Red face Thanks
Just wanted to say thank you all and for this site.
I ran out of fuel last night while heading to flying J. Because of this site and all of your posts, I was able to call my wife to bring me 5 gal of diesel and a 17mm wrench to crack the lines. With out your help I would not know how the get my truck started and be forced to get her towed, and then have it fixed . I just wanted to say thank you to you and my wife.(she knew what and where to find my wrenches )
Thank you again,
Michael
P.S. what kind of fuel filter should I get, and would you replace it, only has 4k miles on it
Old Dec 28, 2004 | 02:55 PM
dzpoorjr's Avatar
Go to Geno's garage for your filters-fleetgaurd dealer! Drain filter at every fuel fill up and change on every other oil change as I was told! Others chime in if I was wrong in my readings-thanks for these forums! Heres the link!
http://www.genosgarage.com/
Old Dec 28, 2004 | 04:35 PM
No need to change the filter yet. Whichever major brand you can get for a good price will do fine.
Ran out of fuel huh?
Old Dec 28, 2004 | 04:49 PM
boiler-rat's Avatar
Drain the filter at every fill up? First time I heard that. Is that recommended? Do you have to prime it when you do that?
Old Dec 28, 2004 | 04:57 PM
The manual says to drain some fuel out of the filter (not the whole filter) every time you fuel. I've never found any water, now I do it maybe once a month if that often. No, you won't lose prime from doing this.
Old Dec 28, 2004 | 10:05 PM
Denis's Avatar
I don't think you have to drain fuel from the filter at every fill-up, as long as you go to a station that has a filthy pump! If you need a glove to remove the handle, it's used frequently, so the fuel is probably pretty fresh.
Tip: if possible go to truck stops near a highway. It's used a lot and is cheaper besides, sometimes as much as 10 or 15 cents per gallon.
Old Dec 28, 2004 | 10:10 PM
greatwhite's Avatar
Drain fuel from filter after each fill? Yeah, I really wanna smell like that. I change my filter once in the spring, and once in the fall. I carry a spare at all times. Have never used it. I've never drained some fuel after a fill. Never had a problem either. Just my .02 .
Old Dec 29, 2004 | 08:35 AM
92DIESEL's Avatar
well thank you to all, I know now that I will NEVER let myself run out of fuel again. What a PITA compared to a gasser. But at least I was able to get her running on my own, thanks to you guys.
I'll change the filter in the spring, and I pull the drain once a month for about 1 sec. just to make sure there is no water. You do not have to drain the whole filter and no need to prime after.
Just my .02
Old Dec 29, 2004 | 12:42 PM
uncleroty's Avatar
I agree, once a month to drain is quite sufficient. Anything more is a waste of fuel
Old Dec 30, 2004 | 11:54 AM
12valve@heart's Avatar
Question
You don't use that diesel scented deodorant so that you can smell like that all the time!?!?!??
What's wrong with you man?
fahlguy
Nov 8, 2002 03:13 PM
Nov 4, 2002 05:20 AM
Palmetto_kid
Oct 17, 2002 08:01 AM
