Technical Fuel Consumption Question
Many years ago I remember reading an article in Mechanics Illustrated about the Mercedes Benz diesel engine. It said something to the effect that Mercedes engines had a built in fuel savings feature that kicks in everytime the driver goes coasting down a hill. Do our First Gen Cummins injection pumps have this feature? In other words are our pumps cutting the fuel supply to a lesser amount when coasting than when idling? If not, does this mean that we are using more fuel coming down a long grade in 4th gear than in overdrive?
Uh, you might want to check your pyrometer...
Less fuel per stroke is injected on overrun than at idle, the governor is trying to slow the engine down by taking away fuel. I don't think you will see a measurable difference between 4th and 5th on a downhill run where no throttle input is needed to maintain speed.
if your pyro drops to zero you got a big problem, cause our engines are compression ignition remember, no heat = no bang = no crankshaft spin = really BAD, there is alot of air and not much fuel moving through the engine but still enough to keep it running.
diablo1
Mar 26, 2010 11:05 AM
avewilson
Mar 28, 2008 05:44 PM
Spook
Aug 23, 2006 10:35 AM
Haulin_in_Dixie
Jul 5, 2004 10:50 AM
