TC replace on a 727 REALLY a good idea???
Old Sep 6, 2007 | 05:45 PM
dizzel's Avatar
Is swapping the tc in my 727 a wise idea or will the stocker hold up fine???
My engine/trans has 400,000 kms on it but I'm not sure if the trans is origional or not.
Will this give me an appreciable mpg gain or should I just wait and upgrade to a 47rh later?
Anyone done the converter on their 727 and see a big difference or if you did it again would you do something differently?
, Dizz
Old Sep 6, 2007 | 06:07 PM
dpuckett's Avatar
I'd recommend a swap. Not sure if the MPG gain would pay for it, but I know of guys who claimed a 4mpg increase with an aftermarket convertor and some valv ebody adjustments.
DP
Old Sep 6, 2007 | 08:02 PM
olddodgetrucks's Avatar
torgue con is a good idea a properly built 727 is industrucable,find someone who builds trans for drag /hot rods this trans was put behind 426 hemis and all kinds of drag cars and were faster than 4 sps. people that tell they are junk prob.never owned one or drove a worn out stock trans
Old Sep 7, 2007 | 12:46 PM
dpuckett's Avatar
How much torque is a 426 Hemi capable of? I was under the impression it was around 500-550 unless you did some real hopping up. Not to say the 727 wouldnt hold, but a 400hp gasser is MUCH different from a 400hp diesel.
DP
Old Sep 7, 2007 | 12:51 PM
rbrettctd's Avatar
The 727 is byfar imo the best auto dodge ever made. If I hadnt been itching for a stick Id have stuck a gear splitter behind my 727 and slapped a torque converter in it and called it good.
Old Sep 7, 2007 | 01:32 PM
dizzel's Avatar
Sounds like a concensus to me fella's! I just spoke to Mark at Hughes and the price and advice are good so I think I found my vendor. Far away from Canada though.....
Mark says that I should check the contents of the pan before I jump to any freshining up conclusions. I sure do appreciate people out there who are honest!!
Old Sep 8, 2007 | 11:50 PM
dandyalgleish's Avatar
I have mine prety hoped up and my 727 is holding up great stock. Where would i be able to find a tc upgrade for mine? The only problem ive had with mine is not being able to go faster after it hits the last gear. Its kinda anoying but i love my truck so who cares...
Old Sep 9, 2007 | 08:22 AM
You need 3200 RPM spring.
Old Sep 10, 2007 | 11:37 PM
if i put in a 3200 rpm spring wont that kill my motor faster? i mean i know the new cummins motors rev up that high but can my motor handle that?
Old Sep 10, 2007 | 11:56 PM
Free89W350's Avatar
The 3200 spring will give you a little more RPMs before it defuel's and it makes it alot more driveable. I couldn't be happier with that upgrade I felt the difference instantly and I also have the 727 auto in a 4x4. DO IT you won't regret it, and by the way it's pretty cheap and easy to do.
Ryan
Old Sep 11, 2007 | 04:13 PM
Only if you insist on driving 100 MPH all the time.
Old Sep 11, 2007 | 11:01 PM
ok that sounds good. But how do i do that? i mean i can figure a lot of this stuff out with some guidence i work on big rigs all day mostly cat and cummins in dump trucks... but please give me an idea of what i would have to do to make it rev that high? Thank you, all of you are very helpfull and knowlegable i really appreciate it cause my truck is my life.
Old Sep 11, 2007 | 11:12 PM
Free89W350's Avatar
Check this out http://dens-site.net/Dodge_CTD/Gover...ing/index.html It's in the Sticky under performance.
Ryan
BTW it sounds ALOT harder to do than it actually is
Old Sep 11, 2007 | 11:17 PM
man that looks good to me but now the hard part is finding time to do it thank you once again
Old Sep 11, 2007 | 11:21 PM
Free89W350's Avatar
It honestly only took me about 45min to do. They say the first time always takes the longest.
