Tanny fluid leaking
Tanny fluid leaking
Hello guys today looked under truck transmission fluid is leaking out of the front trans line where it screws to the bottom side of transmission cooler on right side of motor the line is tight "i am guessing that is transmission cooler on side of motor" any input would be appreciated thank yall
Probably and age also. mine leaked at the conection on the heat exchanger. Really couldnt see anythig wrong with it but we changed it and that stopped it. I will warn you though the line is pretty expensive around 130-140 IIRC.
FAY
03-29-2006 08:14 PM
