Tach Question
Tach Question
I have a 1991.5. I read in the tech section that 1991- 1993 have the factory tach sender. I looked around the crank pulley but I can't see a sender or wires. What am I looking for? Also, I have a black, flat 4 pin connector under the steering shaft that is not hooked up to anything. Is this the gauge hook up? thanks...david
92-93 uses the magnetic pickup as a speed sensor for the computer, so it knows when to turn on the alternator, and a bit of other logic.
I learned that the hard way....( I hate having to dig through schematics for hours)(always ask DTR first)
If you do have the factory tach harness it is nice and works well.
I know this has been covered before and it works for some but not all.I was able to use an elcheapo SunPro tach. It is an 8000rpm tach i had about 2 1/2 inches. I just put spade connectors on the correct wires and put those in the factory plug, set it to 4cyl and works just fine. Just thought i would add that SOME other tachs do work.
