Synthetic Grease?
Synthetic Grease?
I'm going to try it for the wheel bearings. What about all the other grease points?? Will it mix ok? or should I use a blend and then go to synthetic? Or am I throwing money away and should i just use normal grease for everything?
I would us it any time you need to grease......Any thing!
I've been useing synthetic grease for quite a few years now. I switched after looseing a couple wheel berrings and i haven't lost even one since switching. I use it for all berrings, U-joints and the front end of my pu's. I also use it in the high load area's of my tractors like the front end pivot ect...
If i was you, i'd just start useing it for everything on your pu, as over a years time it really doesn't add all that much to the cost of maintance.
Robert
Robert
I have been using Amsoil Heavy Duty grease on my Peterbilt, (and everything else I own for 13 years). 1,286,642 miles, still has all original tie rod ends and kingpins, pins starting to wear a little , ends still tight. Grease every 5000. Most Napa's sell Amsoil.
sisusuomi
0
Apr 15, 2011 03:26 PM
Forty-Two
Oct 22, 2008 11:55 PM
