synthetic gear oil in getrag
It's still too thick. I have had good success with Redline MTL, and Royal Purple Synchromax should also work well if you want an oil specifically formulated for transmission use in a weight comparable to 5W-30 motor oil.
Originally Posted by robert00
is synthetic gear oil as bad for a getrag ar regular gear oil. or should you steer clear of it all together?
syn.
15/40 to syn 5/30 help a lot with gear clash but i'm hoping that the syncromac will help eliminate the clash
I've found that to prolong transmission life, it's more important to change the oil every 12000 miles than to use synthetic oil. Even if the oil looks clean when you stick your finger in the fill hole, the oil always has A LOT of metal in it when you drain it. Shine a light on it while it's sitting in the drain pan, and you will be shocked.
sluggo42
Dec 10, 2006 10:40 PM
