Switzer S200
Old Jun 3, 2010 | 04:45 PM
Bencie's Avatar
Switzer S200
Hi Guys, would a switzer s200 be a choice of a turbo to use on our trucks or not? It looks a little small on both ends. Thanks Bencie
Old Jun 3, 2010 | 05:24 PM
dodgetrucker75's Avatar
depends on the specs, i ran a s200 with a 62mm comp wheel before my twins, and it did just fine, but they do have small shafts and a bit more prone to breaking, but its still going on my cousins 1st gen and he doesnt treat it nice, but you need to know wheel sizes and a/r ratios
Old Jun 3, 2010 | 10:37 PM
Alwaysworking's Avatar
alwaysonDTR
The s200 I had was a 60/60/12cm w/g
Old Jun 4, 2010 | 01:08 PM
dstad's Avatar
Where would one find one of these mysterious turbos ive never heard of. So the s200 is the little brother of the s300. just like hx35 hx40 right?
Old Jun 4, 2010 | 02:24 PM
jimbo486's Avatar
yep. only the 200 is a smaller frame than the 300 where as the hx-35 and hx-40 are based on the same frame. as well as all other hx turbos but i could be wrong about that. cat motors are known to run the schwitzers. both the s200 and s300 depending on the HP. the a/r of the turbine housing will be significantly larger though.
Old Jun 4, 2010 | 09:59 PM
Bencie's Avatar
The s200 I got is from a Mack Midliner non-wastegated, they have a Renault inline 6 in them. They are a discontinued truck for several years now. This turbo has a small compressor housing not sure of the size but the serial # is 10L04-1781 if anyone knows what that means. Maybe a candidate for twins maybe not? Its new old stock.
stillsmokin209
Jan 30, 2012 08:01 PM
Txwelder
Dec 3, 2007 01:14 AM
arenlynn
May 12, 2007 12:53 PM
