Swapping ECM's
Old Jan 1, 2008 | 08:09 AM
GIT-R-DONE's Avatar
Swapping ECM's
I have an external mounted voltage regulator, and found an ecm with it incorporated into the ecm. Would I have to do anything to the voltage regulator to make it work, or can it just be installed without problems?
Old Jan 1, 2008 | 06:40 PM
The '91.5 PCM is unique and will not interchange with the newer models. A '92 or '93 PCM will not work in your truck.
Old Jan 1, 2008 | 07:01 PM
Fred Swanson's Avatar
Dave, if he had the 50pin harness to go with the PCM, that should work, yes/no?
Old Jan 2, 2008 | 06:34 PM
You'd have to swap in the crank sensor.
ratat98
Sep 18, 2016 07:34 PM
6spd05Dually
Mar 12, 2011 12:19 PM
jrussell
17
Sep 17, 2007 06:38 PM
Ohio Joe
Jul 12, 2004 12:13 PM
