Stuck injector
Old Sep 15, 2004 | 04:54 PM
mopar2ya's Avatar
Stuck injector
Im installing new injectors and the rear most injector is flat stuck/siezed. Ive soaked it and used heat and pryed on it. Anyone have a trick or two to get one out?
thanks,
wallace
Old Sep 15, 2004 | 05:01 PM
Guys have meade a homemade slide hammer out of a nut (17mm fine I think?) and bolt with a big socket as the sliding hammer. They say it works great.
Old Sep 15, 2004 | 11:58 PM
mopar2ya's Avatar
I made a cheapo slide hammer. A 8 inch 7/16 carriage bolt, axle nut socket, and a lug nut. Came off in 4 pulls.
On a side note the 60 h.p. injectors work great, I added about 5-6 psi boost and throttle response and boost is quicker.
Old Sep 16, 2004 | 12:03 AM
jiMMyCTD's Avatar
should be able to get a pry bar in there from teh passenger side to pop it out with vise grips on the injector.
jiMMy
Old Sep 16, 2004 | 12:29 AM
lungo's Avatar
I have had injectors on some larger Diesels stick on me and the only way to get them out was to unbolt them lube them down and crank the engine over and watch them fly out. (not a suggested method)
birdboy
Dec 12, 2018 09:02 PM
birdboy
Apr 21, 2012 09:44 PM
Baja
Jan 29, 2008 08:17 PM
WhiteSport600
Oct 23, 2005 07:46 PM
04ctd
Sep 14, 2004 04:43 PM
