stuck in 3rd. HELP!!
The 93 is stuck in 3rd gear, won't budge. its face first up against a fence and we're screwed.
i can't swap in the good trans until the blasted clutch is here that's taking forever!!!
I just want it to go into reverse so we can pull it up near the garage.
Can we tug on it from the back while the clutch is out to try to pop it out or is that a bad idea....
thanks
thanks
Pull the shifter out and have a look. I bet it jumped out, Gotta love the gutbag.
This should help:
https://www.dieseltruckresource.com/....html?t=148533
The pic is broke, but they explain it.
This should help:
It's already up to the garage we rolled it back wards and then just drove it around the block in 3rd to the front entrance of our garage, can't make the clutch any worse so we figured what would a few 3rd gear launches hurt at this point
our buddy is letting us use his snap on trans jack. should be easy. the same guy that gave us the starter spacer we need
sent flywheel out to get cut yesterday, picked up new rear main from dealer...clutch is here....90k getrag is out of storage and painted and ready to go in, just have to bolt on the shifter stick (93 style).....good to go now.
We tried everything to get it unjammed...
The trans has been badish since we got it, its always made that 3rd and 4th gear grumple and shifted really hard (like it had no fluid or something, lol) but for $400 the truck was still a deal because it was so solid.
400k on my drivetrain, including the original getrag, 1st and 3rd detents are out and she groans when lugged but i havent broke anything except an axle shaft and a U-joint yet. (dyno'd at 303hp/769tq corrected)
Clutch? What Clutch? Thought floating the gears was normal. I know that everyone says to not float the gears, but darn, I hate using the clutch pedal. I have had Moose for just about 3 years and once he is moving the clutch pedal doesn't get used.
I will admit that the getrags have small window for sliding the gears, but once you have it figured out, it is not rocket science.
