sticks a lil'
Old Apr 8, 2010 | 10:28 AM
  #31
Rampage1967's Avatar
Feeling like it is sticking / taking off in second or third gear is a governor / valve body problem. The working fine in manual 1 or manual 2 is a dead give away. I bet a wide open take off will force it to take off in low too.
You guys are all going to think I am crazy for this example, but all the Chrysler 3 speed auto trannies including the front drive transaxles work the same. ( Transaxle is a modified A-904 )
I had a Dodge Caravan that did this. It would pull away in high gear at light throttle, but, if you mashed the throttle or jiggled the lever to 1 0r 2 it would work fine. It turned out the fluid was burned nasty from being over heated (rocking to get unstuck) and the crud had plugged the filter, valve body & governor. A good cleaning of all the above fixed it & I never had another problem with it. Before you rebuild, pull the pan & tail housing. Clean the governor & valve body. Adjust the line pressure & throttle pressure settings on the valve body & install fresh fluid & filter. I bet your trans works perfect.
Old Apr 8, 2010 | 11:38 AM
  #32
penguinman's Avatar
Rampage, thanks for the advice. I haven't pulled the tail housing yet. I have put 3 new filters in and cleaned and changed the fluid 3 times. It'll run pretty good for a few days, then be back to normal. When you cleaned yours and adjusted the valve body/governor, and line pressure, did that hold, or were you messing with it again not long after? I just need the thing fixed right. I'm taking it in for free diagnostic at the tranny shop, so, I guess we'll see what the problem is for sure. I will mention what you said to Dave, and we'll see what comes of it. I'll let you fellas know. Thanks again.
Old Apr 8, 2010 | 01:12 PM
  #33
92smokin blacky's Avatar
If nothin else, I would get the transmssion flushed and put in new fluid, filter, adjust bands, turn up the pressure, and put a bottle of lucas trans fix (I've had good luck with this stuff) in too.
here is a link in the sticky i used a few weeks ago when i serviced my transmisssion.
https://www.dieseltruckresource.com/...e-t265745.html
Old Apr 8, 2010 | 02:01 PM
  #34
penguinman's Avatar
I read that sticky link...I wish I would have read that awhile back! I have changed the filter tree times now, flushed and replaced fluids...gaskets...I might just do the rebuild...thats were I am at. I don't have time to be messing with it all the time, hopin' evry lil' thing fixes it...we'll see what Ultimate says...thanks though Smokin'.
Old Apr 8, 2010 | 04:42 PM
  #35
It took me several tries before I figured out I had to remove the governor assembly & the valve body, dissemble them & clean everything by hand. Also, make sure all the parts move freely, even if you have to polish the valves lightly with crocus cloth. After I did that & installed a new filter & fluid with the cleaned parts I never had another problem.
Crud builds up in corners in the valve body & the only way to get it out is to take it all apart for a manual cleaning.
BTW. Seeing the fact you have a 4x4, I understand not pulling the tail housing yet, but, the governor sticking is probably the major problem.
Old Apr 9, 2010 | 03:56 PM
  #36
ebteckx's Avatar
If the governor was sticking the trans wouldnt want to upshift either...
Old Apr 15, 2010 | 09:35 PM
  #37
ebteckx's Avatar
you ever figure out whats going on with your trans?
Old Apr 15, 2010 | 11:02 PM
  #38
penguinman's Avatar
No, I think its what you said though, sticky valve, or somethin'. I don't really want to take it to aamco, even though they will assess it for free. The place I have heard nothin' but good about doesn't have a 6 months no interest like they do (aamco) though either...$2000 bills & up for a rebuild...don't have it at the moment. I might just take it there to get looked at at least....I haven't had the time to do what you told me about, that's probably what I need to do. Been drivin' my Landcruiser mostly but I miss the 20 mpgs. I'll let you know. Thanks again for the help.
Jan 30, 2003 11:49 AM
Jan 18, 2003 05:35 PM
Jade1_78
Jan 14, 2003 10:55 PM
Dec 16, 2002 08:41 PM
Nov 12, 2002 07:14 AM
