Steering Shaft Seal ???
I just received my order of four steering input shaft seals, GATES part # 351320, three for the three dripping Dodge trucks, and one to mess up with.
Each bag contains one seal, one internal snap-ring, one plasticy washer-looking device, and an O-ring of about two-inch diameter.
I have read and re-read the sticky on this, but, alas, no pictures.
I assume the plastic washer thingie is the dust-shield; right ??
There is no mention in the sticky, that I see, of the O-ring.
Where does the O-ring go ??
Also, it mentions a grease that is put between the seal and dust-shield.
I didn't get any grease; what should I use ??
Thanks.
Thanks.
To new to know if posting another board link is cool or not but here you go
http://ramchargercentral.com/index.p...owtoshow;id=93
Scott
Scott
Scott
Scott
Thank you, sir; that makes my life somewhat easier.
I just got my locking nut off last night, however, the adjusting plug came out with it.. Although i counted my turns coming out i dont feel good about having the same adjustment going back in. Appears the locking nut & plug are frozen together, if i separate them my adjment may be further out...I used penetrating fluid but finally got to the point to accept it coming out together.
92smokin blacky
Mar 30, 2010 06:09 PM
OHFarmboy
Feb 25, 2005 11:30 AM
