Steering column play
Previously I asked for help with non-canceling turn signals. It looks like the clock spring was to blame. Thanks guys.
More importantly is the side to side play in the steering wheel. Once the steering wheel is off and the clock spring removed, I can grab the splined stub where the steering wheel nut screws on and move it side to side. It feels like a bad bushing/bearing or something. I couldn't remove the ignition or turn signal clusters because of those fancy little security screws so it looks like a trip to the auto store is in order for a star driver with the little pimple in the center. But in looking at this thing, can I even get into the column from up here? Is there a servicable bearing in there? It looks like it is all enclosed in a steel column.
What is my next step? By the way, the steering itself is tight, it is just the shaft that is loose in the head of the steering column.
Rocky
'93 D250, mostly stock.
Rocky
A junkyard colum is the simplest solution, IMO. Mine's the same way...the bearing closest to the steering wheel locks up every here and there...usually at 65 as I enter a curve....talk about pucker factor!
PurdellMGP
Aug 12, 2003 02:19 PM
brassbuldog
Apr 5, 2003 06:06 AM
scottrod
Dec 13, 2002 03:06 PM
