Steering coloumn pod
Old Oct 27, 2008 | 09:47 PM
peobryant's Avatar
Before I order this pod, I want to make sure it will work in my truck. I have a '91.5 LE D350. I plan on putting an Isspro fuel pressure gauge in it.
Pod
http://www.genosgarage.com/prodinfo....er=GM-DG-15012
Gauge
http://www.genosgarage.com/prodinfo....ber=ISS-R5604R
Old Oct 27, 2008 | 10:15 PM
gear jammer 91"'s Avatar
I heard that you need to have a tilt column to use that pod, but I have no actual experience with it, just what I've heard.
Old Oct 27, 2008 | 11:15 PM
Philip's Avatar
Tilt only and it has to be the later column.
If your column looks like mine it will fit. Here is a side shot of my pod.
Old Oct 28, 2008 | 03:33 AM
Jim Lane's Avatar
How much does that block the view of the speedometer?
Do you get the new top of the housing or is it just the pod you mount to the existing?
Looks nice.
Jim
Old Oct 28, 2008 | 06:15 AM
YOU DO NOT NEED A TILT COLUMN!!
Our 91 has a NON TILT column. and the pod slipped right on and we used the fasteners. just that little tilt lever is not there, so the hole remains empty. it works it works it works
Old Oct 28, 2008 | 08:16 AM
RSWORDS's Avatar
This wont work on earlier truck thogh will it? My 89 has a different column...
Old Oct 28, 2008 | 09:54 AM
Philip's Avatar
Jim it blocks the speedo from 80 MPH and up. At that speed I am not watch gages anyway. I am watch other drivers. So its no big deal there.
The pod slides down over the orginal housing. The pod extends down to the orginal parting line of the top half of the column cover.
Old Oct 28, 2008 | 01:03 PM
ofcmarc's Avatar
Looks nice.
Jim
View from the driver's seat.
Not too much blockage. and what it does block is the upper part (over 75mph)of the speedo where it dosen't really matter. I'm over 6' tall and I can see the speedo to about 85 from my angle.
Fits right over the existing upper half of the coluum shroud. The pod comes with som little plastic push in rivets but I used some small black screws. I think you can see one of them in the pic.
Old Oct 28, 2008 | 03:44 PM
921stgen's Avatar
I have a 91.5 no tilt no nothing plane jane and it fits like a glove, just went and tried the fitment and now a place for the tach again.
BrokeSolid
21
Feb 3, 2009 09:36 AM
scarecrow
Mar 9, 2006 08:12 PM
VueDoo
20
May 9, 2004 09:07 PM
TX Ram
Jan 2, 2003 02:04 PM
scottrod
Dec 13, 2002 03:06 PM
