Steering brace
Steering brace
Anyone know if this steering brace will fit our 1st gen's? Particularly a 93, in my case http://tinyurl.com/5z6e52
That's a good find, if it will work; and, if not, the idea can be made to work by making the leg and welding or bolting it to the stock bracket.
1st Generation Admin
That brace will bolt right in there . . .. for the most part.
It appears to me that the Ramcharger's steering box is a bit different from mine (1993 W250).
I'm working off memory so bear with me .. . One of the top/middle bolts will require a good portion of it's head ground down so as to clear a hump in the body of the steering box (it's tight right there).
You will have to remove the steering box and its mounting plate so you can install at least one of the bolts holding the brace to the frame-rail.
Kylemm1002
07-14-2010 11:56 AM
skindaddy
08-19-2009 08:51 PM
Dan_K
12-19-2008 09:38 PM
05-23-2003 10:04 PM
