Steering Box questions.
Are there any differences between a box off an 89 vs. a 93? I got a box from an fellow member here from his 89 to replace my worn and loose box. I did not take any exact measurements of the two before i put the one from the 89 on because to me they looked the same sitting on the bench. I currently have the box from the 89 on my truck and some how the connection at the rag joint is off by about 3/4" on the one side. This is causing the steering to bind at one spot while turning the wheel.
Any thoughts as to what i might of messed up while swapping the boxes? to me it just seemed like it i needed unbolt the old and bolt the new back up. I took the plate off the frame and pulled the box and plate out together then swapped the boxes.
Here is the connections at the rag joint (without the rag joint to show the offset) with just the bolts in to hold it in place.
well if it is the same box from 81-93 then i guess something somehow got bent. The steering was smooth before the swap and i did not notice the gap before but i really was not looking for anything really either. There are no cracks in the frame or plate.
Flaming river or borgeson would be nice upgrade and the solid double d shaft slides insde the hollow one by design and would take care of that gap nicely.
Last edited by rainfade; Jul 11, 2010 at 03:06 PM. Reason: can't seem to type today
He is the gap with the steering shaft bolted to the steering column flange. From center to center it is about 7/8" off to the right and low.
I am stumped, i took measurements (rough measurements with the box still mounted to the truck) from both boxes and they are the same and everything is good and tight at the box, bracket and frame. All the bolts holding the steering column in place are still good and tight. The shaft coming from the column is not bent and neither is the steering shaft.
I talked to a Tech at borgeson today and he said he never heard of the steering shaft and column not aligning exactly. Why must i always be the first
. He suggested i cut off the rag joint end of my shaft and add a universal. This is becoming an expensive steering box.
I really wish i knew why they were not lined up correctly.
So with the rag joint in place you still can't get the shaft to line up? You do have all the proper bolts and metal retainers to properly mount the rag joint? Your two solid ends of the steering shafts should be opposite each other when howwed through the rag joint.
I recently did the steering box on my crew, 2wd, and had no problems, other then a bit of a fight to get the rag joint, steering shaft and bolts all lined up and bolted down.
Loosen the steering column bolts on the firewall and below the column. Align the column to the box, install your shaft with whatever joint you choose. Go out and enjoy your truck.
Ed
"Some people enjoy the rain, others just get wet."- Roger Miller
Ed
