steering box options
Why couldn't I put in a 73-79 chevy steering box on my plate, use chevy drag link, then take the chevy's shaft to the steering column? I've had it with these boxes going bad, now I got a cracked output shaft. I like the rag-joint close to the steering box, too. Let me know and we can all perhaps be better off. Thanks, Artie
Well, against popular consciences, I directly (no plate on the outside of frame)mounted a Chevy (Saginaw) box to my 93 4X4... Works so much better. I used the Axel's steering arm. I had to ream out with a mortisen reamer, the Dodge's axel steering arm. And I cut off 1/2 in off each Chev drag links, GM front rag-joint, A series 1000 Spicer U-joint on the Dodge's column. My adapter plate with some slight modification, I bolted inside the frame, and ran 4 bolts through the plate, frame and into the steering box. I will gusset the adapter to the front cross member. The truck drives unbelievably better. The chevy's box arm length is 1/2 inch longer than the Dodges steering arm on the Axel. It's very tight steering, is no way squirrelly! I can get some pics if anybody cares?
schoust
35
Mar 5, 2021 12:52 PM
mercedeezel
13
Oct 13, 2013 12:43 AM
04ctd
Oct 5, 2006 08:27 PM
LanceK
13
Jul 14, 2006 08:08 PM
unioncreek
Jun 29, 2005 02:00 PM
