Starting Problems
Old Feb 6, 2011 | 09:44 PM
DLittle's Avatar
Starting Problems
ok I've been playing with the 1973 and drove it around the block today and everything was good just took it easy only went 2 blocks and came back home. Got into driveway and got out to lift the hood and truck died and I haven't been able to start it since. I added 4gal of fuel to tank to make sure draw straw was pulling fuel. I can pump fuel pump primer and get 16+ psi on gauge but when I open injectors very little comes out when engine is cranked ? Any suggestions ?
Truck has started easy up until this point. I have only driven it a few blocks and came home with no other problems. Just trying to get a feel for truck.
When I did swap I killed KDP and advanced the timing 1 tooth and retarded the pump to just under the factory mark since I'm still running factory IC injectors. I also ran a 12v jumper wire to the fuel stop and it still wouldn't start .
I'm open to all suggestion ?
Old Feb 7, 2011 | 08:59 AM
sooty's Avatar
sounds like the fuel shutoff solenoid failed, take it out and check operation
fourthandgoal
88
Dec 27, 2011 05:39 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
doodah
17
Dec 17, 2002 12:55 PM
