Spicer trans swap?
Old Jan 11, 2008 | 02:14 AM
dan1stgen's Avatar
Talking Spicer trans swap?
anyone ever install a spicer 5 spd? ive heard it done to a 12 valve wonder what it takes to do?? would be pretty BEEFY eehhh? divorce the t-case and youd be set. whata yall think?? anyone got any input?
Old Jan 11, 2008 | 05:42 AM
BHD's Avatar
BHD
Most of the Spicer 5spds I have seen are direct in 5th gear, so you would need some kind of browie box or overdrive add on to get your road speed if you have gears taller than 3.07's
Old Jan 11, 2008 | 07:08 AM
JD730's Avatar
You would want an overdrive model like the 3035A or similar, you would also have to do a body lift the clear the bellhousing, most likely a SAE #3. I don't know what you would have to do for a clutch.
Model: 3035A
Gear Ratios:
Reverse 5.90:1
First 6.00:1
Second 3.31:1
Third 1.89:1
Fourth 1.00:1
Fifth 0.85:1
Compared to the NV4500:
R 5.61*
1st 5.61
2nd 3.04
3rd 1.67
4th 1.00
5th 0.75
PeytonMaterne
Jul 25, 2009 12:28 PM
fishin fever
Feb 18, 2005 06:58 PM
apache
Jan 15, 2005 03:48 PM
Dodgeboy440
Sep 25, 2003 03:29 PM
Fishcop
Feb 23, 2003 08:58 AM
