speedometer's doing it again
My speedometer needle pegs at the high end of the scale (ignition on, engine not started)
or
it swings from stop to stop across the entire scale (any speed)
or
it vibrates over a 10-20 mph range (not related to actual speed)
I know this has been discussed before, but my problem may be different because it's happened before and it always went away before I got a chance to diagnose it. (hard to find a problem when it's not there)
I'd rather fix it than wait to see if it fixes itself. Where should I start looking?
or
or
or
or
or
or
Def. electrical if you have problems with the motor off. I would look for a shredded wire, or a bad ground. Mine was screwy for a while and it ended up being the pigtail. As said I would check all grounds, and then follow the wiring harness back up towards the front of the truck and look for any bare wires that could be grounding out.
Steven K
Jun 4, 2009 10:32 AM
