Speedo odometer
Old Mar 8, 2009 | 12:07 PM
Mclair's Avatar
Speedo odometer
My speedo works good but the odometer dosen't work at all. Is this deffently the odometer gears or could it be the vss or something else. I though they run off the same signal so it has to be the odmeter gears right or ? help!!! Also is their a place you can send the instrument panel and have it rebuilt and calbrated
Old Mar 8, 2009 | 12:21 PM
lobsterman's Avatar
when mine stopped working I took the speedometer apart and one of the drive gears were broken. I replaced the unit with a used one
Old Mar 8, 2009 | 12:43 PM
If the speedo works and the odo doesn't, 9 times out of 10 it's the gears.
Old Mar 8, 2009 | 09:28 PM
peobryant's Avatar
Where can one get the gears? I've been putting this off, and need to do it.
Thanks
Old Mar 8, 2009 | 10:48 PM
Power Ram 250 C's Avatar
Thanks
https://www.dieseltruckresource.com/...d.php?t=128685
Here is the sticky on it. I did this last year and it was not a problem at all to do. My little gear was the only one bad so I just replaced it. While things were off, I repainted my faded gage needles. Just a little hint, red at night doesn't show up too good.
fire1861
Jan 6, 2006 11:37 PM
Chrisreyn
Oct 2, 2005 01:02 PM
blackcloud
Jul 20, 2005 09:52 PM
BA05'CTD
Mar 3, 2005 10:36 PM
