does this mean it's broken?
Old Mar 8, 2009 | 07:15 AM
bradshaw106's Avatar
i was changing my fuel filter yesterday and for fun while it was off i gave the lift pump lever a few pumps thinking i would see fuel pump out of the filter mount. but nothing... i also would have expected more resistance in the lever but it was very easy to move. do you think my pump is dead?
Old Mar 8, 2009 | 07:32 AM
Onemoparnut's Avatar
Sometimes depending where the motor stops the lift pump could act like that. Try turning the motor a little then try the lift pump again. IIRC
Old Mar 8, 2009 | 07:35 AM
SeanB23's Avatar
Same exact thing with me !
Operation of lever produces no fuel whatsoever at bleed valve above filter, the one that opens with a 10mm nut, and the lever is really easy to move. Previous owner said he recently replaced the lift pump, too.
I just filled the new filter all the way up to the top with fuel, screwed it on, and it fired right up from dead cold, instantly. Runs like, well, a Cummins. Strong and sure.
(shrugs)
Old Mar 8, 2009 | 08:42 AM
Jet100's Avatar
You have to turn the engine over a little to put the crank in the right postion to pump. it's quite normal and common . once yo do that you will see what i meen. The lever will feel like it's pumping, and if it's good, it will pump.
Old Mar 8, 2009 | 11:05 PM
gear jammer 91"'s Avatar
The lever will also move almost completely straight down, so be sure you are moving it all the way. I thought mine was dead and I just wasn't pushing it far enough down.
Hummin Cummins
Mar 31, 2003 10:43 AM
RLS
Feb 11, 2003 09:53 PM
Jones0027
16
Jan 31, 2003 01:17 PM
1ST GEN.
Jan 12, 2003 10:33 AM
nevrenufhp
14
Nov 27, 2002 09:55 PM
