Speedo
Old Nov 2, 2014 | 03:49 PM
aicomp's Avatar
Speedo
Hi All,
My speedometer reads 51 mph when the truck is doing 65 mph. The only thing new is the vss sensor on the T case. I have not had the rest apart. Ideas?
Thanks,
Mike
Old Nov 2, 2014 | 09:57 PM
Do you know for sure that the transfer case, and the differential gearing have not been changed at any point?
If they have, then the gearing in the TC is probably off, and you need a new ratio adapter. I just swapped from 4.10's to 3.54's on my crewcab, and had to order a +20% ratio adapter.
Here's what you do....Crawl under the truck and remove the VSS, and any ratio adapter that might be there. Then re-install the VSS straight onto the transfer case.
Now use some form to go out on the road and hold a steady 50mph, and record what your speedo is actually register. From there you can figure out what ratio adapter you need to order.
I got mine through these guys....
http://www.transmissioncenter.net/sp...n_______va.htm
Old Nov 2, 2014 | 11:45 PM
aicomp's Avatar
Thanks for that info. I will try it. I got the trans and transfercase from another truck. I don't know what the other truck had. I will try this.
I appreciate your help,
Mike
TJE
Mar 9, 2011 06:48 PM
Paul S.
Feb 20, 2003 05:29 PM
Monty
Feb 9, 2003 05:07 PM
chdiesel
Oct 31, 2002 03:22 PM
