south bend slave cylinder?
Old Apr 14, 2009 | 10:00 PM
W150CTDproject's Avatar
The plastic hose from the clutch pedal pump watchya ma call it to the slave cylinder broke and the parts stores here can only get the slave cylinder. I found a heavy duty south bend complete set up on ebay but for a 94-98. i was wondering if it could be used on my 91 W250? i dont really feel like ordering a replacement from the factory if i can upgrade. Im one of THOSE guys (replace broken or worn with upgraded) lol
Old Apr 14, 2009 | 10:06 PM
bigbaddiesel416's Avatar
From: anderson commiefornia oh ya you can keep the "change"
didnt they go to a bigger/smaller fly wheel?
Old Apr 14, 2009 | 10:08 PM
its the slave cylinder hose for the clutch. i dont think flywheel size matters lol
this is wat i found
http://cgi.ebay.com/ebaymotors/South...Q5fAccessories
Old Apr 14, 2009 | 10:12 PM
oh that's all that registered with me anyhoot i thought your talking bout the clutch as far as the slave i don't know some one will chime in
Old Apr 14, 2009 | 10:14 PM
lol thats ok, i figured that u thought i meant a Clutch, not the hydraulics lol i just need the hydraulic set up. I'd think it would be the same since it looks similar in the pic to my stock one.
Old Apr 14, 2009 | 10:22 PM
how dose the ram operate is it a push or a pull?
Old Apr 14, 2009 | 10:34 PM
it pushes on the clutch fork when pressure is applied
Old Apr 14, 2009 | 10:40 PM
cuz on my 1990 it pulls the linkage
Old Apr 14, 2009 | 10:46 PM
really? My 90 D250 Cummins that i used the engine and bell housing out of, the slave cylinder pushes on the clutch fork, same as my 92 W150. The 91 is a push motion too. i had to use my bell housing cuz the guy i bought the 91 from broke the slave cylinder mount on the origonal bell housing.
EDIT: Is your 90 a manual linkage or hydraulic?
Old Apr 14, 2009 | 10:48 PM
ya iam pretty sure i was dickin with it the other day and thought it was odd that it would push it
EDIT hyd
Old Apr 14, 2009 | 11:06 PM
Riflemanusmc's Avatar
Registered user
Hydro's and manuals push the fork. You have to retract the fork to disengage the clutch...that take's a forward motion on the fork..
Old Apr 14, 2009 | 11:09 PM
so it should work then?
Old Apr 15, 2009 | 02:25 PM
W150CTDproject.
When did you aquire the 91 W250 diesel? I thought you were putting a front difff in your 90 2wd 5 speed?
story? pics?
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
RAFTEN
20
Apr 23, 2007 08:13 AM
Strange
Jan 24, 2004 06:45 PM
