Somethin to do
Old Jul 28, 2005 | 09:52 AM
fearthedeere's Avatar
Somethin to do
Ok my lil brother spoted my down pipe has a purtty good size hole in it. so im gonna cut it off and turn it straight up til i get an 4in elbow and some flex tubin. to complete my 4in exhaust. I will be coming into some money. Neighbor bailed me out with some work. Should make over 300 so i might get it oringed. Also im gonna port the manifold and and clean it and the houseing up what paint should i use in painting it, im gonna paint the valve covers also.
Old Jul 28, 2005 | 05:42 PM
There's no paint that will hold up on the manifold and housing. If you want to keep them looking nice, go to NAPA and get a spray can of Dry Graphite Film lube. It goes on black/dark gray and holds up pretty well. If it starts looking faded just spray some more on it.
Are you cutting a hole in the hood for the downpipe or running it hoodless?
Old Jul 28, 2005 | 10:01 PM
hood less till i get time to weld a new down pipe
Old Jul 28, 2005 | 10:04 PM
BTW how do ya get the injector out. do i need to go but the injector puller
Old Jul 29, 2005 | 01:05 AM
chrisguthrie's Avatar
you don't need a puller to get the injectors out, just loosen up the injector nut all the way and pry up really easy on the fuel line, it should pop out. Just make sure to not pry up to hard don't want to bend or pop a hole in your fuel lines.
Chris
Old Jul 29, 2005 | 01:51 AM
swank's Avatar
WOW chris. that's pretty brave. i can't remember how i got my stockers out though. whatever i did, i think i bunged up the threads pretty good (i was putting different ones back in). i'm sure dave will have an answer for ya.
Old Jul 29, 2005 | 05:57 AM
yeah i wouldn't have done it that way but i had my injectors out about a year ago so i figured they wouldn't be that bad and they really weren't that hard to get out this time. Well maybe i should say get an injector puller to ftd since he's been having all this trouble. not trying to make fun but i don't want something else to happen to his lines.
Chris
Old Jul 29, 2005 | 07:35 AM
ihpower's Avatar
i just put PODS in and to get the old ones out i found a nut that would screw on the top were the fuel tines go. then i used a slide hammer or a pry bar to get them out. they just poped right put.
Old Jul 29, 2005 | 07:36 AM
ihpower's Avatar
oops fuel lines not tines
Old Jul 29, 2005 | 09:12 AM
NeedMoPower's Avatar
A good pair of vice grips works wonders on removing injectors. They give you something to hold on to while trying to pry the injectors out. If the vice grips dont get the job done, a nice pry bar also helps for added leverage.
Old Jul 29, 2005 | 09:37 AM
ok so that means get a injector puller i dont wanna mangle anything
Old Jul 29, 2005 | 03:29 PM
What IHpower said. Get a nut that threads on the injector, then weld that nut onto a nut that will fit your slide hammer, or just make one out of a big socket and a bolt.
Old Jul 29, 2005 | 05:03 PM
bgilbert's Avatar
Jleonard has a pic and instructions on how to make a injector puller in his readers rigs on TDR, not sure if the same pic is posted over here. You get yourself about 12" of 3/8" I believe all thread, some washers and a nut that matches the threads of the injector top, and use it as a slide hammer. Less than $5 in parts from hardware store. Just have to have access to a welder. http://www.turbodieselregister.com/u...=9051&width=0. Here it is, but he doesn't show the thread size.. we need the thread size, anyone?
Edit, from a post by J: The job was made easy with the simple injector puller I made last week at work. I simply welded a 12mm x 1.5 nut (injector top thread) to a 3/8-16 nut. Add a 12 inch piece of 3/8 threaded rod (I have a bunch at home), another 3/8 nut
Old Jul 31, 2005 | 12:05 AM
Last time i priced an injector puller at cummins i think it was around $100
Chris
Old Jul 31, 2005 | 09:55 PM
ArkansasRam's Avatar
I found a nut that fit the injector ( don't know the size) and welded a piece of 3/8 x 8" round stock to the nut. Then i drilled a piece of 1/4 plate about 4" square and slipped it over the rod,
than i welded another plate to the top of the rod. Home made slide hammer and it misses the hood on the last injector. had all my injectors changed to pod's in about 40 minutes. good luck
