Some rough numbers
Some rough numbers
A few people have asked what the lift numbers and the 1/8" bump equate into actual number of degrees so, I did some research in what documents I could find and perusing old threads on a number of forums and came up with the following. Keep in mind some or most of my number are not verified. At least they are a place to start.
Cummins engine VE pump timing: (unverified)
1.25mm pump lift = 12.5° stock intercooled (1.4mm stock non intercooled)
2.4mm additional pump lift (advance) = 21° - 22°
M&H timing spacer increases to 6.4mm advance = 31° - 32°
1mm pump rotation = 1° timing (verified Cummins service manual)
1 tooth on drive gear = 5° translates into 10° timing (verified by counting the teeth and doing the math)
1/8" bump = 3.175° (mathematical equivalent to 1mm=1°)
If anyone can come up with some verified numbers, please post them with the source of the information.
sCreamin400
Nov 2, 2008 01:46 PM
fishin fever
Apr 16, 2006 09:46 AM
blackboat
Oct 11, 2002 11:45 PM
